What kind of Shocks? | Ford Explorer Forums
jeems
Nacogdoches, TX
'92 Sport
Which shocks do you guys prefer? Rancho, Edlebrock, or has anyone tried the Explorer Pro Comp shocks?
bilsteins :)
Gabriel VST shocks. They work great in all situations, and they're inexpensive.
I have edelbrocks....excellent customer service...I had a slight problem and had the new parts in 3 days no cost or questions asked
I have the Gabriel VST's on and I love 'em. Can't beat 'em for the price either. $20 each at Pep Boys.
i have the monroe reflex shocks. they're great for me.
5th Shock absorber
What did you guys do about the small shock absorber that does between the body and the rear axle.
I swapped out my OEM shocks for Edelbrocks. I was hoping that would eliminate the outrageous amount of body sway. As I was installing them I found that small shock (or dampener) and realized this would be the most important element in reducing body sway.
Nobody seems to make a replacement one.
Any thoughts on this????
Thanks,
Rod
Most people on this site just leave the stock 5th shock or remove it. The anti-sway bar and normal shocks are much more important than the 5th shock.
BTW, welcome to the site!
for the 1st 6 months
They worked great for me for the 1st 6 months, then I got pissed off at them after having them for less than 1.5 years & replaced them with Bilsteins. I noticed the difference immediately, and I still notice the difference. It drives better than new right now.
The Discount Auto Parts guy tried to deny my warranty claim on my Gabriels since he said that they are still good, until I asked if I could put them on his vehicle and let him drive on them for a week. He shut up & told me to run to the main store in Jackson, MS since they actually had the replacements in stock. I guess that they either sucks on my Mountaineer or that that Mississippi roads are hard on everything.
After reading about the edelbrocks and seeing them perform on a friends truck, I'd say I would go with Edelbrocks based upon the Million Mile Warranty and the IAS system.
Why would you not get Bilsteins? It was the best modification I have made. They also have a lifetime of the warranty. Get them and you will be more than amazed.
Bilstiens
I wish I had gone with my instinct and installed bilstiens on my '96 XLT. But I made the mistake of talking to a guy that runs an Off-Road shop and he said to go with Edelbrocks because he had never heard anybody complain about them so he felt it was the surer bet.
Having said all that, I'm still not sure that back and forth swaying (not body roll-athough there is a lot of that) will be cured by shocks alone. I think it needs a rear swaybar.
Somewhere I read that the 'add-a-leaf' springs are the culprit and that replacing them makes the most improvement to that sloopy ride.
Rod
I replace my stocks with Gabriel VST's on my `96 and they made no noticable difference at all. Who knows, maybe my stocks were in better shape than I thought, but I would check out Bilstein's or Edelbrocks.
Re: for the 1st 6 months
I'm not saying they suck, i've never had a pair, i have some rancho's on the way. BUT being that i am from Biloxi, MS, MISSISSIPPI roads BLOW! They are hard on everything.
What's the model number of the Bilsteins that you guys are running? I have about six more months to let the crappy Michigan roads beat up on my Monroes and then I want to try some new shocks.
peace
Mike
i put bilsteins on the 96 and 97.also had them on my old
93 that my sister drives now.love them on all.
I had the Gabriel VST gas shocks on the explorer. I had to take em off though. The gabriels caused a lot of vibration at higher speeds.. They were a good stiff offroad shock though. (for stock veicles)
ASP84
What kind of shock do you have now? The reason I ask is that I'm also trying to compare shocks. I'm leaning on to Bilstein also.:bounce:
I replaced mine with Monroe Refelex. A little bit better than the stock but I wanted more.:shoot:
