The difference is not very much between the 2 tires...
I'm thinking for 100 bucks and 30 miles of driving they will be worth it! Especially if they are just about the same size. I just don't want them to look smaller!!!I want to go larger but this is what I can handle at this time. Would these throw my spedo off at all?
Stock Tire - 255/70R16 >Search Tires Tire 1 - 245/75R16 >Search Tires
Section Width: 10.03 in 255 mm
Section Width: 9.64 in 245 mm
Rim Diameter: 16 in 406.4 mm
Rim Width Range: 6.5 - 8 in
Rim Width Range: 6.5 - 7.5 in
Overall Diameter: 30.05 in 763.27 mm
Overall Diameter: 30.46 in 773.68 mm
Sidewall Height: 7.02 in 178.30 mm
Sidewall Height: 7.23 in 183.64 mm
Radius: 15.02 in 381.50 mm
Radius: 15.23 in 386.84 mm
Circumference: 94.40 in 2397.7 mm
Circumference: 95.69 in 2430.5 mm
Revs per Mile: 692.1
Revs per Mile: 682.8
Actual Speed: 60 mph 100 km/h
Speedometer1: 59.1 mph 98.6 km/h
Speedometer Difference: - Speedometer Difference: 1.362% too slow
Diameter Difference: - Diameter Difference: 1.35%
