I keep reading here that the 302's all had 3.73 gears, and that the late 90's 4WD V6 trucks all have 4.10's. I doubt they all do, but the 4WD should be an option which would need the bigger 4.10 gears.
$300 I think is decent price for a good mileage rear, $200 should be a steal, these trucks are now fairly all high mileage.
The 1st gen Explorers have okay brakes, but with lots of miles those aren't as good as the 2nd gen's, the rear discs help in that. I had my 93 that I put hard miles on, constant stopping. Eventually the rear linings wore through the brake backing plate. I discovered it because the front brakes were needing work more often, pads were not lasting as long as they should have. When I discovered the slots worn onto the rear backing plates, welding those up and smoothing it out, that helped the brakes a lot. Both ends are needed, drum brakes just don't do quite as much as discs do.
Keep top brand pads or linings in it, that and fresh fuild will help a lot.
