What spark plugs to use ? | Ford Explorer Forums
Badspell68
NJ
97 XLT 5.0 AWD 4-Door
97 Explorer V8 5.0 XLT AWD
What spark plugs should I use on my truck, is there a high end set that might be better? And what would the spacing be on the plugs?
Motorcraft.
-Rich
Go with the Motocraft.
I herd the Bosch Platniums work the best with Motorcraft Wires
Motorcraft, hands down.
Our experience shows do not use Bosch. Use Motorcraft. If you want to experiment with something different try Autolite Iridium.
whjats so tremendous about motorcraft? im not aksing to start a dispute; only reason i ask is so i can learn. thanx.
--tony
Nothing is "so great" about them.
They have just proven to be the most reliable with
many, many members on this board.
I use NGK IX iridium and coudn't be happier. Crisp throttle response and won't have to change for a very long time. If your asking which will give you the most horsepower, torque. They are all pretty much the same(if you could feel 1-2 hp difference then your better than me). It's just a matter of how often you will want to change your plugs.(Oh and just as important as the plugs, THE PLUG WIRES) Plugs only become important when you go with a blower or high compression engines. Otherwise stock motors don't make much difference.
good luck!
put me down for Motorcraft :thumbsup:
