What To Replace In The Clutch Assembly? | Ford Explorer Forums
explorsive
California
99 sport
Hi I'm Explorsive and I need some experienced input. Here is the problem:
I see no fluid leaking from the master cylinder resivior, lines, cylinder itself, or the line going to the slave cylinder.. But I am losing fluid somewhere. I have to refill the resivior at least once a week, and the pedal stands engaged, but I have trouble getting into any gear when disengaged, until I pump the pedal and the clutch pressure builds. Then it shifts ok.. The master cylinder has a squeek when I disengage the pedal. Is it cylinder, pressureplate, or slave cylinder. NEED EMERGENCY ADVICE... 01/19/2007..... Ok I'm still going on the gimp slave cylinder... Any advice other than OEM as to what slave to get..
I'm looking for a fine mix of high but more so strong (part integrity) performance... And can someone refresh me , when I seperate the housing from the motor, 1. Keep it in neutral?. 2. The pin will line up if I don't move it, right??? Thanks for advice...
I don't know where that fluid is going... If you find out let ME know... Mine has been doing the same thing for over a year, but I don't have any problems selecting gears. I also don't have to build pressure for it to work.
Sounds like either your slave or master is going out. If you do the replacement yourself I would be very interested in hearing where all that fluid has been going:confused:
