What would you guys do? | Ford Explorer Forums - Serious Explorations
SUL73NAZ
AZ
02 XLT
I am stuck in a dilemma, I currently have Rancho Quick Lift Coilovers on all four corners of my truck. I am also running a set of BTF uniball upper control arms. I purchased a set of 2.25" spacers from Brandon before doing the Quick Lifts and the UCA's. It is now tire time and I am looking to install larger tires. I am also going to be doing aftermarket wheels (17x8 4.5 bs). I never installed the front spacers. I am looking to combine the quick lifts and some form of spacer to level the front out (rear still sits higher than the front). Should I just install the front spacers that I have or should I order a smaller set (1.25" or 1.5")? What would you do?
I'm runnin Ranchos with the Truxxx lift on my 4th Gen. It's an ok combo..
What size are the truxxx spacers? (how tall is the spacer itself?) Did you loose all your down travel? Your truck is sikk btw!
