What's the secret to replacing the PCV valve on a 5.0? | Ford Explorer Forums
rs2k
Wichita, KS
2014 Ram 1500 Laramie
None of the results from my searches seems to give any realistic advice... except for the ones that mention removing the engine. After 30 minutes of failure my arm's a scratched and bleeding lump of bruises and I still can't get the valve into the hole. I can feel the hole with my finger and can line it up, but there's no way I can put any force onto getting the valve in. I don't see any tool that will fit back there either. Any ideas?
My hands might just be too big. Anyone know how much a shop might charge to do the job?
OK, hmmm, if you could just get some more room in there. I hate to see you drive it anywhere leaking vacuum like that. That is a HUGE vacuum source.
Let's think.
One way, this is involved, but I can see how it might help. If the trans mount bolts were loosened, the transmission could be jacked up, causing a pivot at the engine mounts. This "should" bring the upper intake further away from the firewall.
can you possibly tape or zip tie a popsicle stick to it to use as a shover?
Can you find a person with long arms and fingers? Big Arms will not do here. I can reach in there but I m all the way over here.
After about 30 more minutes, 30 more scratches, and a nice bump on the head I figured out the secret. You take it to Sears and let them get their smallest guy to spend an hour and a half trying to get back there. Fortunately, their database shows it only takes 0.3 hours to replace (Lies and Slander!) so it only cost me $34 including the valve and grommet. :D Seriously, I've rebuilt engines in less time than this stupid PCV valve took to replace. Curse my huge hands!
I find working on this vehicle is easier than on my 2000 S-10 with a 4.3 was.... except for that dang PCV valve.
Here's how I prefer my engines:
Out in the open and easy to get to! :D
oh man, now i gotta drive all the way to Sears 3 times...
Only if you have big hands.
Amen on the s10 I just worked on 3 Jimmy's with the 4.3 wtf I wish the idiots that engineer this crap had to work on it!
I'm 6'7 297lbs... They're not exactly dainty. LOL. I was honestly considering taking the hoods off to try it.
It sucks but I just take the upper intake off
I thought about taking the intake of, but the intake gasket cost as much as the labor Sears charged me. I admit I felt a bit odd going to a service station for a pcv valve replacement. Lol. My poor right hand is all swollen up this morning. I wish I would have gone to them in the beginning.
For future reference: If you have larger than average hands and do not wish to remove the intake manifold to replace the PCV valve just take it to sears. They replaced mine for $34 including the part.
