slow-demon
- September 28, 1999
- Hawaii
- '91 xl sport
Mine was trying to spin the tires with 36" tires. I blew the rear end up. The center diferential locker was totally in pieces, the ring and pinion had grooves from all the pieces of metal from the differential. I must say I was amazed at how stronp the "Precsion Gear " ring and pinion gear was. None of the teeth was broken (5:13). I still had to change the ring and pinion because of the grooves. The next day I replaced the ring and pinion with a 4:10 set that I happen to have just so I could drive it temporarily till I order 5:13's. I also repalced the differential track lock assy with a used one that a friend had. Had it back and ready to go by noon. Tried to move the truck but the truck would just freewheel. I had a manual trans so I though maybe the clutch went out, but , since I could hear the gears moving in the trans I though something else. I dropped the transfer case. The t-case almost dropped out because the transmission ouput shaft was snapped. Ouch!! Me an my friend took my trans apart and took another identical trans apart that he had. The doner trans had some broken tooth on some gears, but the output shaft was all good. We put my trans back together with the used output shaft and installed it back into the explorer. Had it running at about 5 in the afternoon the same day. Three weeks later later installed new 5:13 gears in the rear so I could engage 4 wd again. Lesson learned........
