I've read on this board of so many people hating the sohc especially in 2000 and 01 explorer why? I haven't had any issues with mine except a bad injector and mine has 180k miles on it. I know the v8 are technically are the stronger engine but those things usually have upwards of almost 300k miles I don't get near the bog down that I did with 91 ohv or the 98 ohv
Happy with our 99’ XLT SOHC and 5R @ 176k . I change the fluids like I change my socks and have since we bought it new. Have replaced the usual suspects, batteries, water pump, radiator, hoses, thermostat housing, coolant, belt, tensioner, alternator, brakes and tires of course. I run a K&N air filter, Wix oil and fuel filters and a Motorcraft trans filter. I stay with Mercon for the trans, transfer case and power steering. It’s a California truck so zero rust which is a bonus, we tow with it as well.
I spent a number of years as a fleet manager so I can attest to the benefits of slightly over maintaining equipment. I have seen identically spec‘d vehicles (all types) under similar conditions on the same maintenance schedule where one is mostly trouble free the other becomes a problem child. With Vehicles and equipment, there are always variables, the driver has a fair amount to do with the longevity of any vehicle, his or her driving habits are a key component to whatever issues you may or may not see in any vehicle.
As an example, having been a commercial driver as well, I would always let the truck tell me what gear and RPM range was most efficient and least aggressive to pull a hill. I do the same with my personal vehicles, there’s a sweet spot where you are not pushing your equipment maxed out at the top of the power band just to get up the hill faster, although you can, if need be pick, up the throttle and gain speed within the range if needed. Warm up and cool down is a good habit to get into in my opinion, even for non turbo charged vehicles.
Now, that’s all good if You start out with a new vehicle, but, when You are buying used, which I have many times, it’s still a crap shoot, then there’s..........
Luck!
