Which electric fan? | Ford Explorer Forums
Which electric fan?
edhand
Kailua, Hi
'92 XLT
I was wondering what model electric fan people had used on their 1st Gens...the flex-a-lite web site said to use the 175, but there isn't enough clearance between the water pump and the radiator. I could put the clutch fan back on, but would prefer electric.
do a search for aldive, i think he has a 180
He has a '99 with a 5.0 .... not the same issues...
Sorry, he has a '99 SOHC 4.0 V6.
I have used 2 different fans on my truck. Both are from Flex-A-Lite ( http://www.flex-a-lite.com/ ).
Take a look at the following threads:
Black Magic 150 - http://www.explorerforum.com/forums/showthread.php?t=75371&highlight=electric+fan
Black Magic Extreme 180 - http://www.explorerforum.com/forums/showthread.php?t=140251&highlight=electric+fan
Either of these fans should serve you well.
Good luck .......
Sorry...guess I wish I had a 5.0...lol
The only problem with these two fans is they have the same dimensions depth wise as the 175 I tried (the 180 is actually 1/16" thinner)...I just don't have clearance between the radiator and the threads on the water pump.
why would someone switch to an electric fan? Worth doing on a 1st gen?
Better gas mileage
More horsepower
Better cooling in traffic or at odle
.... and the list goes on and on.
aldive said:
Better gas mileage
More horsepower
Actually the list is pretty short, you eliminate driving the OEM fan clutched pully,you may pick up some H.P, 2/3, not the 17 as advertized by The company, you may get a tad better Mileage, maybe not.
You will not see any better cooling at odle, the OEM fan do's fine, it just robs some power, thats all.
the main reason I did it is my clutch fan was the original one from the factory and had cracks. Also I felt that the clutch fan wasn't pulling much air at idle...the electric is much better at that. This is important for me because the clutch fan wasn't cooling my A/C condenser enough during the summer months and so my A/C would start blowing warm.
hard to install? makes sense though, i swapped my failed cam driven waterpump on my TA for an electric version, gained 5-7 rwhp from it.
