Bugzturbo
- October 17, 2014
- Collegeville, PA
- 1996 Explorer Sport 4x4
I've researched this swap and have procured the spindles and rotors from an `04 Sport Trac to swap onto my `96 Sport, but with all the info about this, one thing seems to be missing. Which pads to use? I see that you can use either caliper, and found that the caliper brackets are the same for all. So I'm guessing that you need to use the pads from whatever truck the calipers are from. Is this correct. Since the pads fir into the caliper brackets, and they both use the same bracket, I'm assuming there is some minute difference that make the pads caliper specific. Is this correct, or am I missing something? Thanks
