which speed o gear? | Ford Explorer Forums
which speed o gear?
RobbieJ
Albuquerque, New Mexico
91 XLT
I have 4.56s 35's and an auto what color speed o gear do I need to recalibrate it to stock? Thanks Robbie
Robbie
Try going to this url, it will give you the info you require to determine which speedo gear to use.
http://www.explorer4x4.com/speedo.html
You'll need to figure how much your off now, then remove your current gear and figure what you need from there.
does the speedo and odo work off the same gear? or different? The odo is off with oversized tires, too.
Yes
The above link should include larger size tires
