glenmorebuckman
- March 27, 2006
- `Caneyville kentucky
- 02 XLS
I put an a4ld in my 88' bronco II back in July because overdrive went out on my other one. The one I put in is out of an 89' Bronco II and worked fine up till yesterday When I put this one in i decided to baby it to make it last. We live in a very hilly area and I never use overdrive unless I'm on a freeway that is good and level and the speed limit is 65 or over , so I've only used overdrive maybe 10 times since July. I even put an extra cooler on to help out. When I drive in regular D I'm turning 2700rpm's at 55 mph but on the way to work this morning I noticed I was turning 3100 at 55 mph. I shifted into overdrive but it didn't go into overdrive. When I'm in the OD position I can let off the gas and the rpm's drop down to 850. When I'm in regular D rpm's usually go up to about 3000 then it feels like the tranny shifts and they drop to 2700 like it's shifting into a 4th gear at or around 55mph. But since this started I don't feel this shift and the rpm's stay at 3100 at 55 MPH. Also when it was working good and I was doing 55 mph and started to approach a steep hill in regular drive, I could tap the brake and it would make it downshift but it doesn't do this now. I want to hook a voltmeter to the wire going to the shift solenoid and the 3-4 solenoid but I don't know which of the 3 wires at the tranny i hook to for each solenoid.The overdrive worked perfect Sunday and all other gears are working great. Does this sound like it could be a bad solenoid and could someone tell me which wires to check? Cansomeone please tell me the correct way to test these solenoids and to check for torque converter lockup?
