wildstang
- June 6, 2003
- Orange, Vermont
- 91 and 96 explorers
I bought a front and rear end from a early 90's navaho that had 3.73 ratio with limited slip and want to put the gears into my 92 ranger with an 8.8 (I know this is an explorer form but their brother and sister vehicles). I would take the ring gear and pinion from the rear and bolt in to my ranger but I have never done a gear swap in the 8.8. Could I reuse the crush sleeve and be careful not to crush it more, or could I get one of those kits that uses the different shim thicknesses and just measure the hight of the crush sleeve. If I can which would I use to measure, the ranger or navaho? Or do I have to go through and do the whole back lash, gear pattern trial and error method?
Thanks for any help.
