Hokie
Hokius Maximus
- December 14, 2002
- Denver, CO
- '98 TJ Sport
Ok, here's my question. We all know, hands down, the wheel spacers that just slip over your studs are dangerous and can shear your lugs off and all of that bad stuff. My question pertains to the ones that have their own lugs, which you mount to the wheel and to the hub.
I know plenty of people have posted before on this topic, but I don't understand is how these can be any different than a wheel with less back spacing. Here's my thoughts...
The weight of my truck pulls my vehicle down, and my wheels push back with the same force. This normal force is enacted at the geometric center of the contact patch of my tire. If i add a wheel with less backspacing, the moment exerted on the hub is magnified by the distance that the wheels are pushed outward. (Moment=Force*distance)
Since the force on the hub (normal force to weight) will act at the end of the moment arm, how does it make a difference if the wheels are pushed out with by using less backspacing or by using the nice, hub centric spacers with their own lugs. They still mount to the face of the hub, so they don't run the risk of shearing the lug nuts off.
Any engineers out there that can explain why these are bad? B/c this engineering student can't seem to understand the difference between using these and offset wheels.
Thanks!
Thanks!
