The load "arm" of the studs is irrelevant, since the studs connect to the hub/rotor, and that is where the bearings reside.
Spacers put just as much strain on your bearings as using offset rims to achieve the same width. A lever is a lever, envision the bearing surface being the fulcrum, the distance from the bearings to the tire's footprint (length of lever)is what matters, not what the lever is composed of.
Is there more strain on your studs with spacers? -yeah
The idea that use of the same mounting position negates any increased bearing load regardless of an increase in length through off-set rims doesn't compute, that leverage force has to go somewhere.
I must disagree
If you get a set of wheels with the correct amount of backspacing for your truck, but they are a wider width, it is not quite true that you are putting the same amount of strain on your bearings as spacers.
Think of it this way:
The wheel has a balance point, This is the point at which you can reach into the middle of the tire and balance it on a single point. The Engineers at Ford took this into account when designing the front end regarding the backspacing of the wheel.
The had to try to get the mounting face of the wheel as close to the fulcrum point of the bearings, and still be able to fit everything(brakes, ball joints, etc...) within the right track wiidth for the truck.
You can bet that the balance point of the wheels is not over the fulcrum point of the bearings, even stock.
With a properly offset wheel, the balance point of the weight weight is still somewhat properly balanced over the fulcrum point as it was designed, with the same amount of rim on the inner side of the bearings as it was before. The balance point (or Zero leverage point) is not as far away from the fulcrum point of the bearings.
The added weight of the tire/wheel combo increases the leverage when the truck is in the air, but on the ground the weight is irrelevant as the weight of the tire does not push UP on the bearings, thats the weight of the truckpushing down on the other side of the fulcrum point, which did not change with the added weight of the tires, as long as the backspacing stayed the same.
The spacer does more than that. It takes balance point of the the entire wheel/tire combo further out from the fulcrum point of the bearings, thus creating FAR more leverage on the bearings, since there is not as much balance to the inside. This makes the weight of the truck when on the ground act with more leverage on the bearings, even though the weight of the truck did not change, and once again, the weight of the tires is irrelevant since it is essentially being lifted by the force of the weight of the truck on the other side of the fulcrum.
The weight of the
tires only acts on the bearings when the truck is in the
air, when on the
ground (or during impact)the weight of the
truck is the acting force.
This added leverage on the outside of the fulcrum causes more strain to the top of the bearing through upward force when the weight of the truck pushes down on the inside. This also pulls on the bottom of the bearing and wears it that way. Normally the same is true, but not at the levels caused by the added length of the outer side of the fulcrum.
I wish I had a white board... I draw better than I explain...lol
So the spacers are FAR more hurtful to the bearings than the wider wheel with the proper offset.
Keeping in mind that these are 1-peice Hub bearings we are talking about, with no Spindle to absorb some of this force, it can wreak havoc on your bearings, and they will fail MUCH quicker than normal. Like I said before 3 times in a year I had to replace them...
So Im not saying the wider wheel with the proper offset wont have similar effects, but I am saying the Spacer is
MUCH worse for
HIS stock bearing setup, and yes it will cause him problems eventually.
I ran 10" wide rims with 33" BFGs on my Hub bearings for years and they havent failed yet, but I notice more and more play on them each time I inspect. Its a time bomb waiting to go off at highway speed...
![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
