will i need a spring compressor/new struts but lowered springs | Ford Explorer Forums
Eastcoastmod
Halifax,
2003 Explorer Limited 4.6
1.75 drop front 1.5 rear....will it bolt up or will i still need a compressor?
Thanks
Colin
btw new oem struts 2003 limited 4.6
Yes, and you better get a damn good one!! The fronts are under serious pressure! I was doing one with a wall mounted strut tool and the spring bent the ears of the tool and the spring popped out! Lucky for me the top nut was still attached!
Sounds like I should be using a shop :(
No, it is pretty simple and straight forward. I had no issues compressing both original and new springs safely.
I had no problem with mine and I used the cheap set from Harbor Freight. You may be able to rent them from Advance or AutoZone.
I ended up paying a shop...yes they needed the spring compressor. Unfrotunately the springs didn't fit perfectly and a bit of dremel work was needed on the urethane bushings in the front to make it work. It ended up on the hoist for 7 hours...... :( fortunately they only billed my 200 plus tax. :)
