Will Ranger 06 automatic trans fit Explorer 1999? | Ford Explorer Forums
blofeld69
Budapest, Hungary
Explorer 1998 4.0 V6
Hello
Looking for a new transmission for my 1998 Explorer 4.0 sohc
Will a transmission from a Ranger fit? It says the automatic transmission is out of Ranger 06
Here are some codes off the gearbox...
6L5P 7000 EA '977
ASGA1 200905 000095
and off the transfer case... P90GT-7A040-CAR
VIII/2b R3T9A
Just worried that even if it bolts up the electrics wont run it.....
heres some pics of the new gearbox and transfer case
http://aprod.hu/hirdetes/for-explorer-uj-automata-valto-IDO5bX.html
Thanks for your help!
Look at the sensor connector right above the trans range sensor, that sensor is internal on the 99, your wiring won't match up.
Thanks for your help. Just my stinking luck!
Here is a list of transmissions that would fit your 99 Explorer:
1997-2001 Explorer 4.0 V6 models- (5r55e)
1997-2001 Ranger 4.0 -(5r55e)
Basically, most 5r's should fit.
Ford tranny part no: 4188761
What about this? Will this fit? Anyone know what it is? All I have is part number 4188761
Is that the one on eBay from Hornchurch, Essex, UK? The listing indicates it's for 1992-1994, which would suggest it's a A4LD, also incompatible.
That is a 5R55N that will not go in the place of a 5R55E.
