- August 22, 1999
- Celina, Texas
Okay, Now I know from past lifts that there are many things that are interchangeable between the explorer and ranger (91-94 explorer and same year up to 1997 in the ranger)
The largest susp lift for the Explorer is 6" and I am wanting to go 8" in susp (not using spacers on the 6")
Skyjacker has a 8" susp lift for the ford Ranger. The guy I use at 4wheelparts can order just the parts I need from this lift to make it work on the explorer. Here is what I am thinking:
8" drop brackets from Ranger lift
8" drop radius arm brackets from Ranger lift
dropped pitman arm from 8" Ranger lift
Ext radius arms from Explorer Lift
Spring over in the rear
Warrior Shackles in the rear
This should make the explorer sit even. Please tell me if these drop brackets are the same from explorer to ranger. Thanks
