will this lift fit | Ford Explorer Forums - Serious Explorations
will this lift fit
Not for a Explorer. The Ranger kit uses a lift block for the rear(spring over axle). On the Explorer the axle is over the spring. Unless you do the shackles the only two ways of lifting the rear is to a)get new, rearched springs, or b) convert to SOA. Sorry........
will the frount work i know the rear wount but it is still cheaper for that kit then just the frount for an explorer
This is what I did when I first lifted mine. I bought the Ranger 5.5" lift, used the front end pieces, bought a pair of leaf spring pads to move the rear springs to the top of the axle, and then I sold the Ranger lift rear blocks and shocks to reduce my final cost. It worked great. DO IT!!!
