will this lift work? | Ford Explorer Forums
  • Thread starter Thread starter danielrorozco
  • Start date Start date
D
danielrorozco
my buddy found this ad for me and now we found out that if i put this kit on it might make the 4wd not work
does anyone know if thats true
and any opinions if the lift is worth it or not
this was the ad
"I have a Skyjacker drop braket lift for a older ford ranger, GIVES YOU A 6'' LIFT! THATS 10" OF TRAVEL!
i got it from the guy for $350. he only had it on for maybe a season,
i got it an i'm going to go a different way with my truck., i didnt even put it on my truck,ive only had it for a week.
i'm selling so cheap because i just need it gone, i need the money for personal reasons.
it comes with:
I BEAM DROP BRAKETS
RADIUS ARM DROP BRAKETS
6'' COILS
SKYJACKER SHOCKS.
i need it outa my garage, plz give me a call or text for fast response,"
this was the ad
it comes with:
I BEAM DROP BRAKETS
6'' COILS
SKYJACKER SHOCKS.
My ex is stock ride height and I plan on lifting it also.
That kit appears to be missing some items.
Pitman arm
Sway bar brackets
Axle pivot brackets
Bump stop relocation kit
Rear axle kit
That's what some other kits have, You may have a hard time locating the missing items and it will cost more $$$$. I would personally not buy a used lift kit.
But it's up to you.
Pitman arm
Sway bar brackets
Axle pivot brackets
Rear axle kit
But it's up to you.
yeah thats what i want to do, just need to keep on saving the $$. have 2 jobs and trying to get a third:p:
Do the 4x4s even have Ibeams?
Pitman arm can be purchased for $65
Sway bar bracketscan be purchased for about 50
Axle pivot bracketssame as "I-beam drop brackets" or at least some guys call ttb beams I beams
Bump stop relocation kit-not necessary
Rear axle kit see $32 Spring Over thread
That's what some other kits have, You may have a hard time locating the missing items and it will cost more $$$$. I would personally not buy a used lift kit.I would look it over well to see if it's cracked on the axle drop brackets
But it's up to you.
I responded in the quotes.
You WILL also need extended brake lines with this kit or you will rip yours out.
Good move, man. The kits are Hella expensive, but if you're going to use a lift kit, definitely get it either new or from someone you know personally.
thats a good idea to get new cause alot of smaller parts that are really important could be missing
