Window Side Vents / Deflectors
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Nice pics. Does anyone have any pics of their explorers with either the OEM stick ons or weathertech in channels? Im on the fence on both and want to get one soon for my 2018 xlt. Do the stick ons sound noisier? Just want to see more opinions.
Did you look through this thread? There are 50 posts with the word "weathertech" in them and I'd be surprised if one of them didn't have a picture.
thefranchise713
Buffalo, NY
'18 Toyota Prius Prime
I have the in-channels and zero regrets.
jc_slick
New York City, NY
2018 Ford Explorer XLT
Thanks for the input
jc_slick
New York City, NY
Not using a computer and its not loading images. Sounds like me asking bothers you. Maybe there are new users who might want to share their images and experiences.
Stephen Cannon
DFW METROPLEX
2018 Explorer Sport
Weather Tech is the way to go. I have had them on three vehicles and work great. Easy to install and durable. My 18 Explorer has Weather Tech In Channel Vent Visors, cargo and passenger are all season liners, hood deflector and Moonroof wind deflector.
jc_slick
New York City, NY
Thanks stephen. I thought about the weathertech cargo. Curious for the moonroof deflector would look. Is it just for styling? Just asking bc doesnt the netting on the moonroof kinda serve as one? Or is it solely for wind noise?
peterk9
Staff member
Moderator
Callsign
VE3
No bother at all. But why duplicate what may already be posted in this thread. At least I narrowed it down to 50 posts using the 'Search' feature.:)
Stephen Cannon
DFW METROPLEX
2018 Explorer Sport
JC. Moonroof deflector is a bit of both some styling some functional. I had it on my SHO and provided decent aerodynamics and reduced noise. The vent visors and moonroof deflector allows opening of the windows to be slightly open (Vented) without the increased wind noise (buffeting). Although I am not one I understand that the venting comes in handy for smokers during inclement weather (cool, rain etc...) but could also be used to keep windows cracked during cool weather and give the A/C system a break.
jc_slick
New York City, NY
Just put on weathertechs
Stephen Cannon
DFW METROPLEX
2018 Explorer Sport
Definitely recommend the W/T but a caution. I ordered Vent Visors, cargo liners, floor mats everything without a hitch. Note the items and also note the common denominator is NO attachment, all single piece items. Follow me. I ordered the Moonroof deflector here is where the problem came around. The Deflector comes as the following components. 1 Deflector 2 J hook clips (2) 3. Anchor clips that attach to the J Hook (2) 4. nylon screws (2) Washers (2)
I received in the initial order the deflector and 1 J-hook clip. Called back to resend They sent 1 J-hook Clip....Exactly. Three shipments later I finally got all components. Here is the problem/ They don't build the hardware kits up and pre pack all the items in one bag. You could be literally getting eight different bags of stuff or in my case not get eight items. Pre bag the entire hardware kit and place as one item instead of the loosey goosey. When it arrives make sure you get a good inventory of all items first. The assembly is fairly easy but I would recommend getting a helper. One person to center and align the deflector and hold in place. The other person inside the vehicle to align the J-hooks with the installation mounting hole on each corner of the deflector. Mount the Anchor housing to the J hook, run the washer through the screw and lightly install each screw into the anchor clip. Loosely install the screws then slowly tighten up while the assistant holds the deflector in place.
If you are thinking of ClayBar, polish, Wax, scratch removals, anything for the roof I strongly recommend before the deflector is installed. If for some reason you do have to remove the deflector mark where the J hook Clips are positioned so you have a good reference for re installation.
Fil
VA
2019 Sport w/ Safety trim
AVS Ventshade 2019 Ford X Sport
I dont know if this has been posted but I wanted to share my conversation with AVS/ Lunds International. I purchased the Auto Ventshade 194293 In-Channel Ventvisor rain guard for my 2019 Sport and they just didn't fit right in the rear window and the window didnt go all the way up so I sent them back. I reached out to AVS thinking they would just brush me aside as others have stated in the forum, but to my surprise a rep. by the name of Jita has been very helpful and has gone as far as to send me a set to try again and is willing to work with me on fixing the issues I am having. So far they have sent me pictures on how they should be installed and advised me that the rears are not fully in-channel and the tape that people complain about as being on the wrong side of the visor is actually the correct side. The tape on the rear flang sits on the outside of the window channel (as shown in the picture) and not inside the window channel. When AVS and I come up with a solution I will report back.
Ferretkingdom
LEHIGH ACRES
2018 Explorer Limited
Interested in a solution if you find one, as I'm sitting over here trying to decide on what vent shades to get. Lol
Stephen Cannon
DFW METROPLEX
2018 Explorer Sport
Different vehicle but I had the same problem with the AVS In channel guards. I switched to Weather Tech and have had no issues since. W/T is a bit more expensive initially but they work great and are truly plug and play.
peterk9
Staff member
Moderator
Callsign
VE3
Fil, your thread was merged with this existing one found using the "Search' feature.
FYI, there are 43 previous posts mentioning "AVS" in this thread.
MM07
MA
Do you have a pics we can see? I am interested in these.
Do the rears have tape though? Thought I saw that on their site.
J Additional grab handle above passenger side window Modified 2011- 2019 Explorers - Tuning & Mods 3
L Auto window rollup Modified 2011- 2019 Explorers - Tuning & Mods 7
J Automatic Window Switch for Rear Windows Modified 2011- 2019 Explorers - Tuning & Mods 2
L Any issues with folding mirros & window visors? Modified 2011- 2019 Explorers - Tuning & Mods 2
J Window Tinting Modified 2011- 2019 Explorers - Tuning & Mods 113
J Adding Auto Side Mirror Folding System Modified 2011- 2019 Explorers - Tuning & Mods 27
N Adding Side Mirror Turn Signals Modified 2011- 2019 Explorers - Tuning & Mods 7
2 One Side HID Not Working Modified 2011- 2019 Explorers - Tuning & Mods 17
H Changing Side Mirror Turn Signals Modified 2011- 2019 Explorers - Tuning & Mods 10
S I scraped my Sport side rim Modified 2011- 2019 Explorers - Tuning & Mods 12
E Have your tried EGR side steps? Modified 2011- 2019 Explorers - Tuning & Mods 0
R Body colored side mouldings Modified 2011- 2019 Explorers - Tuning & Mods 6
M side vents vs Hood vents? Modified 2011- 2019 Explorers - Tuning & Mods 3
S 2011 Explorer XLT side view mirror convex inserts unsafe at night! Options? Modified 2011- 2019 Explorers - Tuning & Mods 4
SteveAZ Replace side view lighted mirrors with convex inserts Modified 2011- 2019 Explorers - Tuning & Mods 19
D Removing Driver Side Scuff Plate Modified 2011- 2019 Explorers - Tuning & Mods 3
N Adding Fender Vents Modified 2011- 2019 Explorers - Tuning & Mods 40
Similar threads
