0 to 60
- September 14, 2008
- 1996 explorer
I am having problems with the front sprayers on my 02 explorer sport. What is going on is that the wipers will run but no fluid is coming. The lines are not blocked and I don't hear the motor humming when i hit the switch. The rear washer works just fine and so does the front wipers so i don't believe it is the washer pump itself or the actual switch inside the vehicle. I have checked fuse 12 since i believe it is the only fuse controling the sprayers but it is good. Any help would be appreciated ecspecially since I don't have an onwners manuel (I have been working off of the material on the motorcraft website) and winter is coming. Thanks in advance.
