Wiring diagram explorer/ Mustang TPS Swap | Ford Explorer Forums
RubySlow
Pacifica Ca to be S'Pacific
BAYDESTRIAN
Okay so if your interested in Upgrading your throttle body maybe a 70mm or 75mm from a 87-93 you will need this wiring diagram. You can use your stock tps but Only one of the bolts on the TPS will line up on the Mustang T-Body.
So I recommend wiring the mustang TPS to your explorer/mounty harness....
Here is my write up on a mustang T-body
http://www.explorerforum.com/forums/showthread.php?t=193895
Here is the Diagram...
Explorer/Mounty tps wiring is
BRN/WHT - is for VOLT REF.
GRY/WHT - is for TP SENSOR INPUT
GRY/RED - is for SIG RETURN
ok and the Mustang 87-93 Tps wiring is
ORG/WHT - is for VOLT REF.
DRK GRN/LT GREEN - is for TP SENSOR INPUT
BLK/WHT - is for SIG RETURN
dont think harder think smarter that is what my abuelo "Grandfather en espanol" always told me. He said if you are thinking hard then you are confusing yourself. If you think easy then thoughts are free and clear off confusion. Well like i said this mod is worth it. But U may need a new IAC as I did, the mustang IAC is diff than the explorer....
tps
i pick a tps plug on a ford contour to connect mine but the wires are not the same color someone know what A-B-C pins represent
