Jon94
- January 13, 2006
- Guilford, Connecticut
- 94 Sport
I'm buying a 99 Explorer 4.0 OHV from a family member. It cranks, but doesn't start and he's fed up with it, so he's giving it to me. I already helped him do some diagnostics but I still haven't figured it out. Here's what we found so far:
I put a fuel pressure tester on it and there's 65 psi at the fuel rail.
I put a spark tester on it and there's no spark. Although I only tested one cylinder; I suppose I should test the other cylinders?
I checked the resistance of the coil, and it's within spec. I threw on another coil anyway, but it still wouldn't start.
I have power going to the coil.
I tried using a test light to look for pulsing at the other 3 terminals at the coil plug. It barely lit up and pulsed a little, but I didn't really have a probe small enough to get into the terminals and I'm not sure I got good contact. Basically this test was inconclusive.
I tried testing the crank sensor. The wire harness has 3.5 volts on both wires. I hooked up the multimeter to the sensor and cranked the engine. The voltage fluctuated quickly between 6.5 and 8.5 volts. Not sure if that's normal; the Haynes manual didn't say what values I should be getting. I really should've used an analog meter, but I don't have one yet.
I replaced the crank sensor anyway and it still doesn't start.
I was beginning to suspect the computer, but they rarely fail and it still communicates with my scanner. No codes, but the battery was dead for a long time and the memory is wiped. (Has a new battery now)
The tach doesn't move at all when cranking, and looking at the live data on my scanner shows 0 rpm while cranking. Does that point to bad crank sensor? Should the scanner read rpm while cranking, or just when the engine is running?
I don't think it's a PATS issue; the theft light does not flash rapidly and there's no P1206 code.
I'm not sure where to go from here. Thoughts?
