working but...no blinkers! | Ford Explorer Forums
smood74
Honolulu, Hawaii
'96 XLT
sorry i dont know where to put this but...
k i have no blinkers nor hazards. i accidentally crossed the ground wire from my turn signal to a "hot wire" doing the alternating mod thing. anyways i checked all fuses and they're all good and. changed the flasher because i thought it was it and still NOTHING! k guys help me out here cuz im cutting everybody off left and right. any help is much appreciated!
Check the bulbs and the flasher relay and if that doesn't do anything, then more than likely its your multi-function switch/stalk.
on my 88 the relay for the hazards is on the back side of the dash fuse box, the parking lamp flasher is a seperate relay.
Without the hazard flasher the turn signals also will not work.
Not sure if its similar on the later models
But I did replace the mutlifunction switch on a 95 this weekend, no low beams.... :P
