AudioDreams
- November 6, 2014
- Mayfield, KY
- 2007 Jeep JKU
On a 2002 Sport Trac I am working on, I found the broken wires in the boot under the bulkhead connector on the driver's door.
I replaced the master switch, the new one illuminates now..
When I unlock the windows, the driver's front goes up automatically as if the button is pushed although it is not...
When i push the driver's switch down, there is a relay clicking under the dash
The Passenger front window works correctly
The Driver rear window works correctly
The Passenger rear does nothing.
I can use a power probe to raise and lower the driver's window.
I have not tried the passenger rear, it is a lower priority
I have installed a third master switch with the same results.
Can someone save what little hair i have left and point me in the right direction on what to check next.
