yet another sea foam question | Ford Explorer Forums
kdogg212001
stockton, california
94 xlt
ok i have just got into the whole sea foam cleaner!! out here in california, well where i live i guess its new!! i talked to some of the guys at auto zone and they said they have just got it in and have no opinions on it really!! i am just wondering about it, i understand putting it into the gas tank, but the other places....... such as the vaccum lines and any others!! what are some of the benifits i should be noticing from this sea foam?? the first thing i am going to do is put a pint into my gas, and what should i notice from that?? any help and other understanding ??? thanks
Just use it through a vacuum line. I've run it through all the other places and noticed nothing. There's a vacuum line under your throttle body. Run it through there.
ok i ran it through the brake booster line yesterday but onlt noticed a little bit of smoke nothing like what the other post shows in the pictures posted!! but a little, as far as that line under the throotle body how do you recomend getting the fluid in that hose i mean that hose is very small!! i had a little bit of trouble getting the funnel into the brake booster line!! do you think after running it once through the brake booster line i should still run in through the throttle body line???
Extend the vacuum line with a rubber hose that'll give you a seal when you connect the two and stick it in the can...let it suck the seafoam.
Just make sure you idle up to keep it running.
I think mines addicted to it...it takes it in the gas tank. :p
yeah i was supprised when i had teh brake booster line off and it was running it was running rough but as soon as it was getting some of the sea foam it idled fine till i stoped pooring it that is!! so any idea on the size of a hose or anything else i need to do that??
Hey, huskyfan, I'm having trouble discovering which line you mean. Where does it start?
Peace (and thanks),
--Jim--
It's right under the throttle body. Pull off your intake tube to get to it. I'm not sure where it starts but it connects right under the TB. You wanna buy a foot of tube in this size, pull the stock tube off the TB, plug in your new tube and let it suck the sea foam. I rev the engine to around 2000 RPM as it's sucking so it doesn't suck too little or die.
