Your TPS specs please!!! | Ford Explorer Forums
X-North
Montreal
I need to know your Throttle position sensor specs to compare it to mine.
My engine is a 4.0 OHV from a First gen explorer.
Don't take time to write if you will only tell things like "If the truck work then it's ok". I need those specs to be sure.
First unplug the plug of course and make those measures please.
Resistance on the tps where those wires normally plugs...
1-Grey/white and Brown/White
2-Grey/white and Gray/Red
3-Brown/White and Gray/Red
I got a 53 code it tell TPS range too high or throttle stuck open but my truck is running good and after i tested my incoming voltage on tps sensor its fine thats why i want to check the specs before buying another one for nothing.
Thank you and have a nice day
