Please read the whole thread, as has been posted, adjusting the TPS is only for EECIV and older Fords. It does nothing good for 95/96 OBDII and newer Fords.
The TPS should be about 1 volt at idle, not any precise amount at all. It does not matter one bit if it's a little higher or lower. Not one bit.
Unless the TPS idle voltage turns out to be far far from 1 volt, say 0.6 volts or 1.4 volts, leave it the #### alone. If it's far far off, the TPS is bad and must be replaced, not adjusted.
For OBDII and newer, the TPS is either good or bad, it is not adjustable. This myth needs to be in a dumbass section of things to not waste time on. Excuse me for being honest, but stupidity bothers me a lot. Regards,
