TFCeddieB
- January 5, 2009
- Eastern Shore, MD
- 2005 Eddie Bauer
i was feeling it until the rca's lol.
you have a aux button on your headunit can you not get an adaptor from pac usspec for additional imputs from that?
if you pull the rea entertainment peice down you can cut your rcas and connect them to the back of the rca plug its really easy to do. and it plays clear.
just curious whats the button in between the cup holders in the front do..haven't seen that before
just putting tweeters on the c post would not be good,, the very high frequency sound would be all them people in that seat would hear,, you would be better off to put another full range back there, even if it was just a 3 1/2 inch 2 way on each side,,
clean install! i just got done doing the same thing but with 2 hella 500's. i just ran my power wire for the switch to the battery and it works but now its causing the alternater to overload b/c i got a 1,200 watt amp too. Any way, i need to run it to the fuse box but am not really sure how. i saw one picture u had of the fuse box. so u ran that wire to that metal piece? did you need any extra fuses to plug in? any info would help thats!
