moga
- March 2, 2009
- Atlanta
- 1998 Mountie 302 AWD
Aggie, my mountaineer, is near and dear to my heart. However, she has had saggy butt syndrome since day one and I have no more patience for seeing her in that condition. To my disappointment, there wasn't much difference in ride height after replacing the shocks and rear springs. Now I plan on replacing the stock shackles with Warrior 153s to see if I can't recover the missing ground clearance that way.
While I'm at it, should I replace the axle damper too? If I'd known that such a thing existed when I put in new shocks, I would have had it done then. It was only recently when I bled the brake lines for the first time that I beheld the weird shock absorber thingy connected to the rear axle. On one hand, I know that the quad shocks don't impact the ride height, so it won't benefit Aggie that way. Yet on the other, I worry that I may leave that base uncovered which doesn't make sense given how far I've gone to correct the issue so far. It can't hurt, right? What about how she hits bottom kinda hard when going over speed bumps at normal street speeds (~30 mph)? Will replacing the dampers help with that at all?
Also, does any other manufacturer beside Bilstein make them? They're kinda pricey at $180 for a pair. I'd rather get another make to cut down on the expense if at all possible.
She is strictly a daily driver if that at all matters.
