custom winch mpount
Chiming in here based on turdle's PM request..... i have all the detailed photos of my winch mount behind the factory bumper assembly, but i will have to remember where they are and will follow up. my winch is Ramsey 8500. I originally set it up so the cable would comeout through the little holes in the tupperware air dam, but i didnt like the look , so i eventually cut away the center portion of the airdam. (photos to follow)
in summary what i did was
1.removed bumper assembly
2. welded in two 2" angles on inside of frame members (at right height to allow cable through airdam)
3. cut a universal winch mount plate to width and drilled holes for plate to angle.
4. centered winch in space and drilled for bolts (winch to plate).
5. rewired controller to locaqtion in the top of engine compartment
6. cuss and grumbled as i realized that winch assembly now blocks access to bumper mounts.
7. learned how to be contortionist with extentions, etc and reconnect the bumper.
8. weld in two shackle mounts at the point where the factory butterfly bumper mounts can be seen after the body lift.
there is some sequencing issue like perhaps whinch has to go on plate before plate goes to frame, and bumper extensions have to stay with frame. as well if i remember correctly, .
