ddave
- July 28, 2010
- Ft Lauderdale FL
- 94 XLT
Hello.. I've replaced the clutch, pressure plate, slave cylinder and pilot bearing in my ranger. Before I threw the tranny back in I put it in first so I could line up the splines easier by rotating the drive shaft. Everything went in fine. Reinstalled the drive shaft. Now the gear shifter appears to be in nuetral but the tranny is still in gear (can't roll the truck). I haven't bled the new master cylinder and slave yet. Is it normal that the truck is still in gear and would installing the new clutch master cylinder and bleed the system fix that?
I just don't want to install a new clutch master cylinder and bleed the system (what a PAIN) if there is already a problem with it being in gear.
