Originally posted by '96explorereddiebauer
Oh man...I just did this mod a couple of months ago. It's awesome!! Autodimming/Autolamp mirror was an option for every model except Limited, which was standard, and XL, which was not available. Anyways...I don't know if the wiring colors changed but here it is...
First, remove the old mirror. In order to remove the old mirror, insert a flathead screwdriver at the bottom of the mirror and put up. The mirror will slide out. To install the new mirror, just slide it in.
Then, if you're going to the junkyard and get the mirror, be sure to get the mirror and the wiring harness. Get as much wires from the mirror as possible because you'll need it. You'll might need extra wires because I needed more wires so I could tap the wires onto the overhead console harness.
Next, in order to get to the wiring harness in the overhead console, you need to take the console down so you'll have access to the wires. If you have a sunroof, open it then pull the plastic molding right behind the console. After pulling that out, go to the front of the console and yank that thing down.
If you don't have sunroof, open the garage door opener compartment door and unscrew the two screws then go to the front of the console and yank it down.
Alrighty...and the fun stuff begins, I tapped the Power (Light Green/Yellow) and the Ignition (Red/Yellow) from the mirror to the Power wire (Gray/Yellow) in the overhead console. I haven't grounded anything yet so now, I had to tap the Ground (Black) wire from the overhead console to the Ground (Black) wire from the mirror and voila! You've got AUTODIMMING mirror.
Good luck. This is a very simple mod and should take you about 30 minutes to do. It's well worth it. Again...good luck!!!
