jd4242
- October 15, 2008
- va beach
- 92explorer&94 ranger
cooling head mod how to
Here's a link to the cooling head mod: How to Install the Cobra Engineering Cylinder Head Cooling Mod
Interesting write up. I should look into that mod. I mounted my throttle cable bracket right over the driver's side freeze plug. When I got the engine it had an out let on the pass side, but I removed it and installed a freeze plug to make room for my heater hoses. SMH. I should look into this for my dad's cobra also. He has an '04 terminator. I change the pass side tube when he got the car because it was leaking. It was not fun... I finally got coolant in mine and the maf hooked up. I took it for a little spin in the parking lot. I am going to like it a lot. Still need to hook up the imrc controller and pcv system, but it's drivable again!
You ever look into this?? The Aviators didnt have a coolant tube coming out of the passengers head like the cobra..obviously you could still do this mod as i am but the question is which heater core line should you ""T"" into?? Assuming the return? Would it still flow out of the heads into the line or would the heater hose try and feed the heads?? Pretty stupid question but hey figured id ask..lol
