02 sensors/Purge valve | Ford Explorer Forums - Serious Explorations
dchag79
Chicopee, MA
2010 Explorer Limited
Hoping someone can help. I am getting all 02 sensor codes P0050, 54, 60 and purge valve P0443. I have replaced all 02 sensors. The purge valve. The purge canister valve and put in a new ECM. Still getting the codes. Any ideas? Anyone else have this issue?
Bump, hopefully this post could get more attention.
Just curious, could it be a harness/ground issue? When there's not a good ground, all kinds of weird codes may pop up.
Have you done a thorough search of the forums for threads covering the same problem? There are plenty of threads that have covered the issues you are having and one probably holds an answer for you. Also, around holidays forum activity goes down.
