exam099
- May 28, 2013
- Michigan
- 2002 Explorer XLT V6 4x4
I have a 4x4 2002 X V6 130,000. was driving 70-75 on freeway and had a loss of power. Has rough idol revs high and shifts fine (but still shifts through all gears) accelearates extremly slow. will not go over 40 (unless going down hill). starts fine, does not stall, has rough idol, will go into all gears, has no acceleration, will replace fuel filter, air filter, will also be going to parts store to have codes read. will check trans fluid level.
All suggestions are welcome. Will repost with more info once coeds have been read.
Update camshaft position sensor circuit malfunction.
Replace sensor took off valve cover no oil getting to center valve cleaned out oil tube restored oil to valves. now have serious tick. also have new code p0320 ignition/ distributor engine speed input circuit malfunction
UPDATE 6-26
Have been told could have jumped a tooth on the timing chain. Runs rough sound to be misfiring and alot of unburnt gas comming from exhaust. Sound like a possible cause to anyone?
UPDATE 6-26
