FordNut01
- October 5, 2015
- western suburbs of chicago illinois
- 2005 ford explorer
Starts out, I started up my 05 Explorer one morning, pulled out to the street and when I went to take off it was like I was trying to take off in 5th gear, then it jumps into 1st gear and everything seems ok until I stop again. then it starts all over again. got on the main road and shifted through all the gears ok but the OD light started flashing, and OD was jumping in and out. got it home and hooked up my OBDII and got a pending code of P1716 (shift solenoid C malfunction replace ssc) so I ordered the part online. when I received the part I went to back the Explorer into the garage and it would go into reverse but it would come right out of reverse like it was in neutral, I would put it into park and back into reverse with the same results. finally pushed it into the garage and replaced the Shift solenoid Pak, replaced the filter and installed all new mercon V fluid. it seems ok in D (but have not driven it yet) but in reverse it still pops out. ANYBODY WITH ANY IDEAS PLEASE HELP THANKS
