06 timing chain rattle
mprince75
Ohio
2006 Ford explorer
I have read several posts about this death rattle , confirmed today it’s coming from the front. However it’s not very loud and makes no noise at startup until it warms up. My question is how many people have had this where it makes no noise at startup until it’s warm and how long did you drive it or did it last before it died?
Littleant
Location
Vermont
Orleans
2010 Mountaineer 4.0
How many miles on the engine/vehicle. I assume it's a 4.0
mprince75
Ohio
2006 Ford explorer
Yes it’s got 174,000 and it’s a 2006, I thought Ford updated something on the newer 4.0. Got an estimate to do the front chain for about $900 was wondering if I should just try to replace the tension or what.
explodermann256
2007 Explorer XLT V6 4WD
They did update many of the timing components by 2006, but they never updated the rear guides.
Unfortunately, even with the updated components, many of these engines wound up having timing related issues.
How loud is your rattle?
mprince75
Ohio
2006 Ford explorer
The rattle is silent at startup and is low to moderate after it’s warmed up and driven for an hour, that’s why I was wondering if the tensioner it’s might be bad, seen a video with a louder rattle and the guy put a new tensioner or on it and it instantly went away. Just tying to find a cheap fix . Every post I read talks about it being so loud at startup and mine is silent.
explodermann256
Check my thread. Tensioners helped somewhat mitigate my cold start rattle, but not completely. During operations however, since changing my tensioners, I have no more rattle.
Will changing my timing chain tensioners do more bad than good?
doug625 Looking to buy a 4th gen. Do any 4.0s exist without the timing chain rattle? Stock 2006 -2010 Explorers 22
J rear timing chain Stock 2006 -2010 Explorers 1
D Do these models have the timing chain issues Stock 2006 -2010 Explorers 14
R 2006 V8 Eddie Bauer, 300k miles. Timing chain, guides, tensioners Stock 2006 -2010 Explorers 3
E Will changing my timing chain tensioners do more bad than good? Stock 2006 -2010 Explorers 23
H Mileage to do timing chain, guides, and tensioners? 4.6l Stock 2006 -2010 Explorers 13
J 2007 4.6 timing chain quote$ i got Stock 2006 -2010 Explorers 20
A timing chain tensioners Stock 2006 -2010 Explorers 13
F 2007 4.0L Timing Chain Disaster Stock 2006 -2010 Explorers 5
0 Replaced the rear timing chain tensioner today Stock 2006 -2010 Explorers 9
S 2006 4.0 Timing Chain Noise? Stock 2006 -2010 Explorers 10
L Opinion - Timing Chain Replacement (2007 4.0L) Stock 2006 -2010 Explorers 16
J Timing Chain Cassettes in 2008 4.0 liter SOHC-Reliability verdict? Stock 2006 -2010 Explorers 28
E 4.6 engine, issue with timing chain tensioners Stock 2006 -2010 Explorers 6
K Possible timing chain woe Stock 2006 -2010 Explorers 4
08EddieCA Rear (RH) Timing Chain Tensioner - Anyone recognize this part# TC.40.A.302 40 Stock 2006 -2010 Explorers 7
0 Timing chain tensioners Stock 2006 -2010 Explorers 9
L 2008-2010 any timing chain issues 4.0 Stock 2006 -2010 Explorers 19
S Timing Chain Guide and Tensioner on an 08 4.6 3V - When to do ? Stock 2006 -2010 Explorers 2
M timing chain tension torque Stock 2006 -2010 Explorers 2
F Timing Chain Mess Stock 2006 -2010 Explorers 3
S Cam Phaser or Timing Chain Tensioner Stock 2006 -2010 Explorers 22
R 2006 Explorer 4.0L V6 timing chain tensioner socket size Stock 2006 -2010 Explorers 1
M Timing chain repair/Georgia Stock 2006 -2010 Explorers 0
A Front Timing Chain Guides and or chain Stock 2006 -2010 Explorers 22
K 2008 xlt timing belt or chain Stock 2006 -2010 Explorers 10
K 2006 Explorer - Timing Chain Question Stock 2006 -2010 Explorers 46
X Timing chain noise Stock 2006 -2010 Explorers 7
Z Timing Chain symptoms recognition and replacement Stock 2006 -2010 Explorers 2
R oil leak, grating noise & timing chain tensioner found in oil pan Stock 2006 -2010 Explorers 10
E Timing chain replacement on 06-10 v8's. Stock 2006 -2010 Explorers 7
T Timing chain replacement cost Stock 2006 -2010 Explorers 2
P Timing chain noise??? Stock 2006 -2010 Explorers 7
M And we thought the 4.0 timing chains were silly Stock 2006 -2010 Explorers 10
H Have timing done by a mechanic? Or just replace the whole engine? 4.6l Stock 2006 -2010 Explorers 4
E Looking for a shop in NY/NJ/PA able to rebuild timing on 4.0 Stock 2006 -2010 Explorers 5
D Around What Mileage do the Timing Chains Give Up? Stock 2006 -2010 Explorers 8
E 4.0 v6 owners - we are not alone, stupid timing design. Stock 2006 -2010 Explorers 1
E 4.0 v6 timing noise questions and options. Stock 2006 -2010 Explorers 13
08EddieCA Timing Cover - chewed by water pump - replace timing cover? Stock 2006 -2010 Explorers 1
B 06 Rear Timing Cassette /Interference Engine Stock 2006 -2010 Explorers 1
R Timing the 4.6 lite 3 valve - timing work. Stock 2006 -2010 Explorers 2
K Random Timing Malfunction... Stock 2006 -2010 Explorers 0
J 2006 Explorer 4.6 Timing Guides Stock 2006 -2010 Explorers 11
T Cam timing questions Stock 2006 -2010 Explorers 1
2 Explorer 2007 4.0 with 206,000 miles Timming Chain Stock 2006 -2010 Explorers 15
B Good Times lol Something Stupid? or Lost compression, Skipped time or broken timeimg chain? Stock 2006 -2010 Explorers 12
C Engine Noise, Chain and lifter Photo Stock 2006 -2010 Explorers 5
R Rattle/vibration coming from exhaust Stock 2006 -2010 Explorers 1
S AC Compressor Rattle at Idle Stock 2006 -2010 Explorers 9
Similar threads
