Shoktronic
- October 11, 2013
- Nevada
- 2007 Explorer / 2008 F150
Ok I am stumped & need some input.
Here is the rundown. 2007 Explorer, 2wd, 4.6 w/110k location Vegas / South Carolina. Had a leak from the heater hose / rear air manifold. Had it replaced 12/2018. Coils were also replaced & injectors serviced at that time. We had the fan constant on/off issue for over a year after we had the coils replaced (non OEM). Fan clutch was replaced by the shop but same issue persisted (again non OEM). We drove around with this since I couldn't find a solution. No overheating issues "that we noticed".
September 2019 being fed up with noise I replaced the water pump, fan clutch, thermostat, radiator cap, pulleys, tensioner & belt (All OEM). No change to the fan noise, no cooling issues "that we noticed"
I finally found the thread here & swapped the coils back to Motorcraft ones & it fixed it! Fan only came on under heavy loads, AC... The normal stuff. This was done just before we moved from Vegas to South Carolina (02/2021).
So... We have been here for a little while did some grocery runs, nothing too far. The car was transported, not driven BTW. Had to pick some things up about 75 miles from the house or about an hour drive. Noticed the fan kick on a little more than normal but no lights or temp fluctuating. On the drive back home shortly after we arrived here I had to speed up a bit after exiting a shopping center (goosed it). Almost immediately after getting off the accelerator I smelled coolant & saw steam out the right fender. Popped the hood and the top heater hose was split along the top 8" to 10". So had a shop repair it.
Now I'm having issues of the fan coming on a lot which has me concerned. Duh out my OBDII to check the temps using Torque Pro. OBDII says 220-230, dummy gauge no change. Fan kicking on at 210 - 215, loss of power on side streets when temps jump. Had the local shop run the gambit on tests & nothing. No head gasket leaks, oil is clean, coolant is clean, no CO2, pressure test was fine & No air in the system.
So I'm not sure what to check or replace. It does appear the heater core may be plugged as it's not "hot" but only warm. Rear air is an oven. If it's plugged I'm not sure if the radiator might be plugged? I haven't done the temp check yet on the hoses. My infared gauge gets in tomorrow.
It's a new area so I don't know how "good" the repair shop actually is.
I know cars & can turn a wrench but cooling systems ain't my forte.
Any input / suggestions would be GREATLY APPRECIATED!
If you need any other details just ask. I've tried to be thorough, albeit long winded.
Thanks
Thanks
