Maryserv
- August 27, 2021
- Richmond
- 2007 Explorer Eddie Bauer
2007 4.0l 158K miles
I've read through all the posts possible over the last year and a half and have replaced parts based on symptoms. Over the last year, I replaced the fan clutch and thermostat which helped with overheating for about a year. Recently, when overheating started again I have block tested, replaced the thermostat housing, replaced the water pump (after repeated flushes of yuck), replaced the thermostat again (twice), replaced the radiator cap (tested to ensure holding correct pressure), replaced the coolant temp sensor. I've had a Ford-only mechanic look at it and a primarily American engine mechanic look at it. The coolant can get to boiling in the overflow reservoir. I did a prestone clean and flush. The radiator was supposedly replaced before I bought it. The heater core seemed blocked so the place I bought it from did flushes until the heater worked.
Tested the fan today when the engine was hot and off. Fan does move both ways but with some resistance, certainly won't rotate 3 revolutions. The Ford mechanic I'm talking to says that something is stopping the coolant from flowing correctly. The upper hose is very hard when the engine is hot.
I just don't know what else to do. Any ideas? I would appreciate it!
