whodunit
- September 13, 2022
- San Diego, CA
- 1987 Ford Ranger
My ranger has had this issue for a little while now. It shifts great until I'm giving it some gas (usually uphill) in 3rd and get above 35mph or so. When it shifts into 4th it will quickly drop back into 3rd and then go back into 4th and so forth until I either give less gas (so it stays in 4th) or give it more gas to basically keep it in 3rd. It feels like theres an area right between 3rd and 4th gear that the truck can't decide where it wants to be. Hopefully that makes sense so far, Its hard to explain.
I tested the vacuum modulator and any vacuum line I could get my hands on. The modulator held vacuum but the line to it didnt. I replaced the line and now it holds. I did find another leak or two in the process of searching the rest of the vacuum system and replaced all the tubes with new silicone ones but the shifting issue persists. I adjusted the transmission bands, cleaned the valve body and replaced the transmission filter and put fresh fluid in. I've replaced the TPS and the MAP sensor but I wasnt able to find motorcraft parts for those so I can't say for sure they're good parts.
The things I haven't done yet that are on my suspect list is inspect the servos, inspect the VSS and adjust the kick down cable. I'm wondering if anyone can help point me in the right direction based on the described symptoms.
Thank you!
Thank you!
