- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
Gates water pump
I was able to source water pump / timing cover bolts from another engine in the shop. This is a great way to store 5.0 waterpump
Bolts
Each bolt was cleaned with drill and wire wheel
New gasket sandwiched w permatex copper
Ford calls for thread sealant on the bolts that go through waterpump, through the timing cover and into the engines water jacket. Many 5 oh dudes will also use silicon here… but i still do fords way with the thread sealant
Surfaces prepped scraped, wiped w alcohol prior to gasket install
Next the heads and head gaskets
Bolts
