- November 11, 2005
- Brooklyn, NY
- 88 89 93 95 96 Aerostars
The gas filter could be clogged. Do you hear the fuel pump prime when you turn the key?
If you have no power at the intertia switch then the problem is in front of that. THis rules out the fuel pump, crank sensor, and coil. In front of the inertia switch are the ignition switch, PCM, PCM relay, and fuel pump relay and associated fuses. I'd concentrate on the PCM and fuel pump relays. Does the CEL come on when you turn the key to the ON position?
