In no particular order, here is what I can find that I've purchased for the project so far. I have a few extra gaskets left over.
Engine Stuff:
Melling M328 oil pump - Amazon
6x Speed Pro SLP-H570P piston set - Summit
12x Melling MR-927 Rocker Arm - Amazon
Dayco PB1103N Harmonic Balancer - RockAuto
Ford E7RY-6A340-B bolt for balancer - Amazon
Victor Reinz 72115 Oil Filter Adapter O-Ring - RockAuto
Fel-Pro 72884 Oil Filter Adapater Gasket - RockAuto
Fel-Pro BS40647 Crankshaft Seal - RockAuto
Cloyes 94172S Timing Set (chain, gears, tensioner, guide) - RockAuto
Mahle/Clevite MS2006A Crankshaft Main Bearing Set - RockAuto
6x Mahle/Clevite CB723P Connecting Rod Bearing - RockAuto
Sealed Power E613K Piston Ring Set - RockAuto
Fel-Pro TCS45291 Timing Cover Gasket Set - RockAuto
Fel-Pro VS50368C Valve Cover Gasket Set - RockAuto
Motorcraft RT1161 Thermostat - RockAuto
Morana 10.9 Re-usable Head Bolt Set - Tom Morana Racing
http://www.moranav6racing.com/
2x Victor Reinz GS33221 Cylinder Head Bolt (not used, cheaper TTY set, 1x per head req'd) - RockAuto
Fel-Pro 544SD Left Cylinder Head Gasket - RockAuto
Fel-Pro 545SD Right Cylinder Head Gasket - RockAuto
Fel-Pro MS98005T Intake Manifold Gasket - RockAuto
Fel-Pro OS34309R Oil Pan Gasket - RockAuto
Westar EM2641 Motor Mount - RockAuto
Westar EM2643 Motor Mount - RockAuto
Fel-Pro MS94764 Exhaust Manifold Gasket - RockAuto
Fel-Pro 35474 Water Pump Gasket (extra) - RockAuto
Trans stuff:
3x ATP FO101 Servo Seal - RockAuto
2x SuperSize Performance Servo for A4LD - PATC (
transmissioncenter.net)
Sonnax 56000-CS6 Crankshaft Spacer - PATC (
Wix 58841 A4LD Transmission Filter 4WD - RockAuto
