Notta
- June 26, 2014
- san francisco,CA
- '95 Ford Aerostar 3.0
I have a '95 3.0 with a troubled history, too long a story for here, x-cept that it was broken into, & ignition lock was pretty destroyed in an attempt to make off with it. I managed to piece together the bits, with a few homemade pins & a little JB weld. It worked for about 2 years, pretty much normally, when an incident occurred where while driving, all dash lights went on, check engine, everything- my thought was it stalled out as I was coasting up to a red light, so I used the key to restart but 'grind!' it had not stalled out! So I kept on, as my destination was close, but then, the key would not go from 'run' to 'off'! WTF! It would go from 'run' to 'start', though after a couple weeks, froze up in 'run' position- could not stop it, could not start it, but it would run, as well as it ever did, which was well, well!
After a couple of weeks of choking it down via air input,(remove plastic tube from throttle body, put hand over opening, remove battery neg cable,) starting by reconnecting everything & shorting adjacent posts on item on fender wall, (starter relay?) where battery pos cable goes.
After many tries, many curses, got lock cyl out & got new one from O'Reilly. have not been able to get it to go into opening completely after days of trying. new cylinder turns freely when in my hand, but won't budge in the column, (won't go in completely, or, what it engages inside won't budge).
Stumped! Any thoughts on this? Also, ABS & Brake lights on always, since incident.
