1935explorer
- December 3, 2022
- Wareham mass
- 1996 explorer
I’m trying to figure out how to hookup a Holley sts pcv switch and check valve but I’m confused. It’s for a 1996 Ford Explorer 5.0, this is what directions say in attachment and I can’t figure out the where fresh air source comes from ? Or other sources ?
1. Fresh air source – This port will typically be between the MAF sensor and the throttle body.
2. Crank case port #1 – This port will be hooked to the fresh air source.
3. Crank case port #2 – This port will be hooked to the intake manifold port.
4. Intake manifold port – This port will evacuate the fumes from the crank case under non-boosted driving
