eric mentzer
- December 10, 2017
- Pennsylvania
- 1996 XLT 4 door 4wd
hello, 1996 explorer abs seems to be engaging at every stop sign right at the tail end of the stop. peddle pulsates rapidly and buzzes. its a control trac 87000 miles 4wd (2wd, 4wdauto, 4low). truck is hardly moving at all and only happens at very low speeds. getting more frequent with no fault codes. I tried replacing the cheap sensor in rear differential. Any other ideas? rotors and pads are decent. Thank you. thinking about pulling the fuse to abs but i dont like to jerry rig
