CAGERATTLER
- February 2, 2009
- Baltimore, MD
- 2002 XLT
Im in need of some quick help or thoughts on what could be the problem with my GF's 02 Explorer before we have it towed to a shop.
1st off some quick specs.........
02 Explorer XLT
4.0 V6
4WD
not sure which model tranny
80,000 miles
Truck was bought used and had about 50,000 miles on it.
Theres been no service done to it that we are aware of including fluid or filter changes which i know should have been done.
Long story short (hopefully).........
The truck has run perfectly up till yesterday. No signs of any tranny problems at all. No slipping, no clunking, no grinding noise, no hard shifting. The only thing we've noticed is a slight 1-2 second delay when putting in reverse.
Yesterday when coming home from a short trip, I stopped at a stop sign at the end of my road and when i started to take off, it slipped momentarily and then grabbed. 1st sign of anything wrong!
Pulled it in the driveway and went to go somewhere later that evening and then nothing! It wont go into any gear at all. The shifter feels normal going up & down through the gears, but no gears grab at all. Just feels like every gear position is neutral.
Jacked it up this morning to see if i could see anything. The shifter arm (on the side of the tranny) is moving when going through the gears. Tried to see if i could find any electrical connectors loose but no luck.
Sounds to me, since there was no real warning signs and no gears at all engage, that it is probably an electrical problem somewhere (hopefully).
Stopped at a couple shops today to try to get some ideas and prices on any repairs. Only prices they would really give me was a top end price of $2000 - $2500 for a total rebuild. Not what i wanted to hear obviously!!
I was hoping to get some prices of what it would cost if it were this or that but i understand that they wont know what they got till they get in there.
The one place told me its not an electrical problem and sounds like something broke inside because it should still go in reverse even if its electrical. In other words, he said not going into reverse could only be a mechanical problem.
Is that correct or is he blowing smoke up my rear??
Before i have it towed to a shop ........Any thoughts, Ideas or tips on how to proceed would be greatly appreciated.
Im a decent back yard mechanic but have never worked on trannys and dont really have the time to learn and experiment right now unless there are any relays, sensors or switches i can check myself without dropping the pan.
Thanks
By the way .... I just registered to post this but looks like alot of good info here (yes i did some searching before making a post) and i also have a 94 Ranger, so this site looks to be one i will be frequenting often.
02 Explorer XLT
4.0 V6
4WD
80,000 miles
Thanks
